Michael
I've been toying with these Luxeon white leds and the data calls for a
current regulated supply.
I'll assume the reasoning for any LED to require a current regulated supply
is for a consistent, unwavering brightness level. (?)
So, I went ahead and built an LM317 in current regulated mode with a couple
of these Luxeon's in series as per the application info and all seems well
(except one seems a bit dimmer....that could be another issue....they talk
about bin numbers alot which could be "batch differences"?).
Fact is, every application shows these LED's wired in series (yuck?) with
"current regulated power supply".
Anyway, my question is this....
If the LED is the only thing in the circuit and is fed through a series
limiting resistor, the current is going to be constant anyway, right? I mean
there's nothing else in the circuit to affect it.
If the power supply was robust enough, wouldn't it be the same thing to use
an lm317 as a voltage regulator and run
my (2) led's with resistors in parallel to the supply buss?
I don't get it....the current is constant either way. ?
I'd rather do the latter because I wouldn't need a higher voltage for the
series supply.
If I did parallel, I could just whip out a good old 6.3vac xformer.
Thanks.
series supply.
Thanks.
