Current limit for 5V @ 120mA
I am working on something that can limit the current draw from a 5V source with current of 500mA. But I wanted to limit the current draw to only 120mA.
May i know how should I do that, or is there a standard IC that can do it, I try to search for current limit IC but can not find one that is giving 5V @ 120 mA
Please help
Please explain further what you are trying to do. If you intend to hook up a device that requires 120mA at 5V, you can connect it directly to a 5v, 500mA supply. It will use only the current it needs.
The rule for power supplies is that they must provide the correct voltage and at least the required current. In fact, you should normally allow a margin for the current, never run a power supply at the maximum current, or it will likely fail early.
If, on the other hand, what you want is something will set the voltage to whatever it takes to push 120mA into the load, you need a constant current source, as Minder said.
Bob
davenn
what Bob said ......
