Dave King
I am trying to understand the practical implications of the differnece
in current flow between a SE vs. BTL amp.
First I take a length single wire and fold it over in half flat upon
itself so the two fly leads are at one end.
Then I connect the leads across the output of a earth referenced SE
amp and apply a sinewave to its input. The current now opposes in the
adjacent conductors and magnetic flux tends to cancel. The
cancellation obviously reaches its highest intensity at the peak of
the waveform.
So ... does the same effect occur if I were to use a BTL amp instead?
In this case the current flow is bidirectional (push/pull) per single
cycle, not one way. Does this mean two flux cancellations per cycle
will occur, given the above wire configuration?
Keep in mind that everytime the flow reverses at full amplitude
represents a cancellation event.
I can't get my head around it for some reason.
Dave King
the waveform.
Dave King
