CRT TV Mitsubishi CT29AS1 Vertical deflection problem?
Hi all
I've been scratching my head for days to work this out.
My mitsubishi Crt TV CT29AS1 has gradually deteriorated. The top 1/3 of the picture is stretched. If I display a service test picture for geometry the circle ends up looking like an egg at the top. I have the service manual and have tweaked the service mode. However, I cannot adjust anymore.
Can someone help me by advising if it is the vertical deflection circuit and a bootstrap capacitor before I take it all apart and discharge?
Any advice would be amazing!!
Thank you
G
I have no dismantled the TV and discharged it. Before I start recapping the whole board can anyone advise me of the deflection circuit and usual problems or capacitors that might go?
bertus
Hello,
I tried to download a schematic and got an elbe E19 schematic.
Is this the deflection part of your TV?
If so have a look at Q301,Q302, C307 and C308.
If not, do you have a link to the schematic?
bertus
bertus
Hello,
It looks like the vertical deflection is done by a TDA8178S:
There are some scope test images in the schematic.
Bertus
bertus
Hello,
What happened in this corner?
It looks like someone tried to solder something and touched the plastic frame.
Bertus
bertus
Hello,
It looks like they tried to solder this region:
So to see it is in the audio part.
Bertus
Yes they have!!!! Why on earth would someone do that. Either way I don't use the audio on the TV as it runs via my amp.
In regards to the vertical deflection, will I need a professional to scope it? Or can I just replace the capacitors?
Many thanks
So upon inspection q550 solder was dry with supplies vpos. However upon putting it all back together the linearity is still poor. Any other ideas?
Update
After turning the TV on and testing voltages unfortunatly my avo meter grounded 2 pins on the ic. This took out a resistor, I have subsequently replaced the resistor and also 2 capacitors in the vertical ic.
The picture is now a white line which i presume is the Ic tda 8178s burnt out because I grounded it accidently.
1. At least the TV turns back on now after replacing the capacitors (bad values tested with esr meter)
2. I have managed to source a TDA8178S for the mitsubishi deflection circuit.
3. Not sure when it will arrive but is there any other caps I should check to ensure no other problems?
Any advice on the white line would be great!!!!
