Crown D-75 Power Amp, Pot & Cap
Jimmy Lee
Hello,
I have a Crown D-75 amp that is missing a cap on the on-off switch.
Does anyone know where I can purchase one, or maybe something cheap I
can squeeze on there?
Also, one of the volume pots are scratchy. I haven't tried cleaning
it out yet, but in the event that I need a new pot, what kind of pot
can I purchase and where's a good place to order from?
Thanks,
Jimmy
E
Eeyore
Jimmy said:
Hello,
I'd suggest contacting Crown. Those things are often quite specific to
the manufacturer in question.
http://crownaudio.com/
Graham
the manufacturer in question.http://crownaudio.com/
Graham
Mpffff... The cap is nothing special at all. About any 600+VDC 0.02uf
or 0.01uf ceramic disc cap will do just fine.
The volume-controls _will_ be specific to that amp, but if you know
the specifications, you should be able to find after-market
replacements or upgrades. But I would strongly suggest you clean them
before you replace them. Be sure to use a *lubricating* cleaner
designed for volume controls - or, if you know how to be very, very
sparing in your application (flame-suit full-on) WD-40 - after a non-
lubricating cleaner such as mineral spirits or the like. Even Radio
Shack tuner/cleaner is excellent in this application.
NOTE: ALL OF THE ABOVE ARE FLAMMABLE. Allow all volatiles to escape
before applying power.
Peter Wieck
Wyncote, PA
