Robert Morein
I have a Yamaha EF3000iSE AC generator, rated at 2800 watts continuous.
This unit uses "inverter technology", which means that it uses a DC
alternator to power an AC inverter.
A Xantrex SW4024 charger-inverter is a computer controlled combination of a
charger and inverter, for AC power backup.
The intent is to use the Yamaha on the generator input of the Xantrex to
charge a battery bank.
The Yamaha circuit protection trips after a few minutes of operation.
No significant current is being drawn. The batteries are already on float.
The Xantrex has programmable current limiting for AC sources. Reducing the
allowable current draw from the generator to 10 amps has no effect on the
behavior.
I have tested the Yamaha with two 1500 watt "cube" heaters. The Yamaha
supplies 3KW into these resistive loads without problem.
I conclude that large current pulses, typical of switching power supplies,
are glitching the Yamaha protection circuitry.
This is a serious problem. I'm wondering if I could salvage the Yamaha for
this use by placing a ferroresonant device between the Yamaha and the
Xantrex.
One possible device would be the Sola sine-wave neutralized units. However,
they are expensive.
I tossed one years ago (sigh!)
Suggestions?
behavior.
Xantrex.
they are expensive.
Suggestions?
