Cracked Lenticular Screen
  • Thread starter command line to start gmail account
  • Start date
Does anybody know:
1) How to get a Pioneer PN#AMR2559 for a SPD5075K (lenticular screen),
or a similar replacement (I hear you can sub from another maker)
2) How to replace it from the set?
Jumpster Jiver
command said:
Does anybody know:
Shop all your local TV repair shops for the same size or larger screen,
which can be cut to size.
Each TV is different, so you must figure out how to remove the front
frame and screen assembly. Some snap off from the front while others
screw on from the rear inside. Then you must seperate the two screens.
The inner part is a lens which can not be substituted with a different
paart. The outer lenticular screen is virtually the same on all rear
projectors and can be subbed from any brand/model. The screens will be
screwed together within a frame, or maybe even taped together on some
models.
G
Glen
You sure about that last part? I thought the pitch of a lenticular
screen had to be matched to the radial cut of the Fresnel lens,
or else image distortion could result. At least that's what our
Sony repair dude told us.
Art
Depending on your wallet and the critical nature of your viewing. Other
lenticulars may be subbed without noticeable loss of quality. However, for
best detail you may want to consider getting the original items. BTW have
the fresnal been damaged also or just a crack in the lenticular?
Andy Cuffe
I tried this once, but there was an interference pattern between the
lines in the lenticular screen and the fresnel lens.
Andy Cuffe
[email protected] <-- Use this address until 12/31/2005
[email protected] <-- Use this address after 12/31/2005
L
Leonard Caillouet
If you are swapping for a used screen, why not just swapp them together?
Leonard
