L
Larry B
I have a Panasonic cordless phone and the 3.6vdc Ni-Cad batteries fail
pretty quickly. I measured the voltage to the charging contacts and it is 11
VDC. Seems like a quick-charging, short battery life scenario. Please
confirm.
I put a potentiometer on the + side of the charging leads and found that it
took 10M ohms to get it to drop to 6vdc. With the battery rated at 850mAh,
is it reasonable to put in a dropping resistor?? If so, what kind of
resistor can I use to drop the voltage without turning the phone into either
an expensive space heater or even a plastic-melting fire danger?? Is there
another way to do this??
Thanks!! LarryB
confirm.
Thanks!! LarryB
