COOL TOY! The Ion Chamber.
For this neat-o thing you need a small darlington NPN transistor, a can, tin foil, a rubber band, drill, wire, multimeter, 4.7K resistor, and a 9v battery. drill a small hole in the top of the can and stick the base-pin of the transistor through it. Solder one end of the resistor to the can and the other to the + wire of the battery. Now solder a wire to the Collector end of the transistor to the terminal of the battery. Attach the - wire of the multimeter to the wire to the Emitter. Attach the + of the multimeter to the can. Strap some tin foil w/ the rubber band to the open end of the can. "now thats fine and dandy ultra... But when would I ever use this?" This device measures radiation, mainly alpha and beta. get your hands on a fleck of uranium ore and place the can tin-side down on the subject and watch as the numbers on the multimeter climb! leave your comment on how this worked for you!
Fish4Fun
So long, and Thanks for all the Fish!
I followed all the directions but I am having difficulty locating uranium....I put all my stuff in a backpack and went over to the nuclear power plant, I figured they'd have some for sure and might let me have a little bit to test....the security guards were very narrow-minded about my request and insisted that I leave immediately! When I tried to explain I just needed a tiny bit, more guards showed up and things were beginning to look a bit scary. I am not certain how many of them they thought it was going to take, but I am fair certain on how many they were going to use....
LMAO, just poking fun ultrafire3, sounds like a cool project.
Fish
davenn
there's a lot of rocks and minerals out there that have traces of uranium and other radio-active elements in them. I have a few in my collection
Even the good ol' smoke detector found in most homes has a radioactive source
All these things make my Geiger counter tick wildly :)
Dave
