Converting VU meter design to single power supply
Tom Corker
I'm looking inot building a VU meter based on the design at
http://www.4qdtec.com/avu.html. This design specifies a +18v-0v-18v
split power supply. However, I need to run it from a 12v single power
rail.
Can I just tie the bottom of the LED set to ground, instead if -18v
via the 2 transistors?
Also, would BC109 transistors be suitable?
I am something of a beginner in electronics.
Thanks.
Martin Griffith
rail.
Thanks.
All the leds are in series, and yoy will drop over a volt on each one,
so that is the minimum rail that you can get away with, plus a bit
more for safety.
Look at the LM3914/3915/3916 from national, far more friendly, and
will work from 12V and will be more stable
martin
E
ehsjr
rail.
Thanks.
You need a different circuit to use a single 12 volt supply
and light up 10 LEDs.
Ed
E
Eeyore
rail.
You can't, there won't be enough volts to illuminate all the series
leds..
Graham
E
Eeyore
Rather more than a volt. At a few mA I use 1.6V as Vf.
Graham
I'm looking inot building a VU meter based on the design athttp://www.4qdtec.com/avu.html. This design specifies a  +18v-0v-18v
rail.
Thanks.
Yoicks, try something that's from this decade. That design is
ridiculous overkill and needlessly complex.
Jim Thompson
Surf on "bargraph"... IIRC National makes a chip ideally suited for
this purpose.
...Jim Thompson
Tom Corker
That was the main reason I wanted to build it. I know the purpose
specific ICs will do a better job, be cheaper, less complex etc, but I
really wanted to have a go at building something more than just an IC
and a bunch of LEDs. I'm building it more for the fun of it than any
actual practical use.
I've found a more suitable design at
http://www.talkingelectronics.com/projects/StereoVUmeter/StereoVU.html
Thanks for everyone's advice.
On 5 Feb, 19:52, [email protected] wrote:> Yoicks, try something that's from this decade. That design is
I actually understand that, being a tube geek at times.
And the first thing you wanted to do was find out which parts you
could change or throw away!?????
I've found a more suitable design athttp://www.talkingelectronics.com/projects/StereoVUmeter/StereoVU.html
The LM3914 has been in production for *decades* and is still
available.
http://www.national.com/mpf/LM/LM3914.html
"Full production"
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=2556426;keywords=lm3914
Spajky
I'm looking inot building a VU meter ..., I need to run it from a 12v single power
rail.
check my site (down) under electronics for another schematic (LED
logaritmic Peak audio meter 4 PC) ...
