Converting phone handset audio to PC soundcard line-in audio
I
Isaac Grover
Hi everyone,
I have been recording weekly conference calls since January, and I'm
looking to upgrade the quality of my recordings. Currently, I'm
connecting my cordless phone to the line-in jack on my PC's soundcard
with a 6' audio cable.
I would like to take the audio from a landline telephone, so I tore
apart the handset on my wired phone to see which wires connected the
handset's speaker to the base. I saw that it was pins 2 and 3 (top
left and bottom right), so I connected pin 2 (green) on the handset
jack to ground on a spliced audio cable, and connected pin 3 (red) on
the handset jack to tip on the audio cable.
I can hear the audio from the phone line, but not without problems.
There is an intrusive hum that almost drowns the phone line audio, and
whenever pin 2 (green) is connected to ground on the audio cable, my
wired phone's base takes the line off-hook, even if the handset is
still on the cradle.
So can someone tell me how to eradicate the hum, and how to keep the
line on-hook if I am not using my "high-tech" conversion device?
Thanks,
Isaac
Do you make $100,000 per year? Do you work from home?
Do you want to?
http://www.globalsuccess2000.com/nonstop_income/opp/flash_opp.html
Rich Grise
Hi everyone,
Use two capacitors. Measure all your polarities, and use about
100-220 uF caps at at least 250V. These will be electrolytics, which
is why you need to know the polarities. This will isolate them, unload
the phone line, and not ground the telco's system.
