Converting petrol cars to electric
The Doctor
Hi all,
Are there any kits available? Where can I buy one from?
Can it be done to any car?
The Doctor
[email protected] wrote in [email protected]:
Yes, there are kits available for some cars, VW Rabbit/Golf for
instance. See http://www.electroauto.com - not the only seller of such
things but a good start.
To see a successful DIY effort, check out www.kiwiev.com.
Most successful conversions that I have seen use lead-acid batteries,
but while these work OK, they do suffer from the twin problems of
weight and limited battery life (300 - 500 cycles).
Lithium-ion batteries are now starting to become more readily
available, Thundersky is one brand that looks very promising. Li-Ion
batteries offer less weight than lead-acid for the same capacity, and
if the manufacturer's claims bear out they should last for 2000+
cycles.
Performance of the converted car will depend on several variables,
mainly battery capacity and motor power.. A good performance envelope
to aim for is to get better than 100 kph (60mph) maximum speed, and to
be able to maintain that speed for better 1 hour on a charge.
Thank you. What about the cost of Li-ion batteries?
Range?
K
krw
Thanks. Finally some constructive response instead of the usual "you are
stupid and you don't know anything..."
"Finally"? You waited three weeks to check back, and cop a
"finally" attitude? ;-)
