converting line-level audio signal to resistance?
Mad Scientist Jr
Can someone explain how you would take a line level audio signal and
conver it to resistance in the range of 0 - 1 MOhm? Any help
appreciated...
K
Ken Taylor
appreciated...
Three things come to mind - the last two are to amplify it and drive a servo
motor connected to a 1MOhm pot, the other to run it into a A/D converter and
then use that to drive a digital potentiometer IC. The first thing is what
are you trying to achieve?
Ken
Mad Scientist Jr
AUDIO> is positive or ground or both?
[C} is capacitor? how much?
[R] is resistor? how much?
what is [LDR] ? is this a light sensor ?
[LDR] has 2 outputs, do these go to the +5v and gnd of the paddle?
What is the [POT] between Gnd and Vcc? Is this to adjust the gain of
the audio driving the LED?
What is Vcc?
thanks
Then I wrote and crossposted to sed:
Not really. Just view it using a fixed pitch font like Courier and
if it still doesn't make sense post back with what you don't
understand.
+---[R]--+ +---->OUT
| [LED]--> [LDR]
AUDIO>---[C]----+-----+--|-\ | |
| | >--+ +---->OUT
[R] +--|+/
GND>------------+ |
[POT]<--+
Vcc>------------+
