I have an old coleman powermate generator (it was only $100) that outputs 5000W at 220V . It currently has a NEMA15-20R outlet.
My house, on the other hand, is newer and has a NEMA NEMA L14-30 port on it that's hooked up to a sub panel to power various things (like a well pump, for example.)
I'm thinking that I can create a female L14 connector, connect the ground wire to the chassis of the generator, then connect the G of the 15-20R plug to the neutral of the L14 plug, and then connect each of the hots on the 15-20R plug to the two hots on the generator - which should let me power both busses and get 220V where needed.
Does that make sense, or does it seem like I'm gonna burn my house down?
Also, I have a 50' lon L14-30 cable - is that too long to actually make work properly , or do I need to use something like a jumper cable to jumper the generator chassis to the electrical panel (to get an ideal ground?)
thanks!
thanks!
