I'm looking for some help on the issue as mentioned in the tread.
I would like to build a converter in order to have a modern processor controled, gas heated, water heater that will only work on a 50Hz sine wave (as tested - with a small generator - it does work A-OK) in a country where the mains supply is 115VAC, 60Hz.
The generator is not an option as it is much to noisy and we dont use hot water during most of the day.
Many years ago I have build a converter for a friend to provide 115VAC/400Hz and that worked just fine but was probabely much to complicated and was only for a small power source and for a demostration.
It used a crystall controled oscilator circuit and several opamps to convert the oscilator frequency to 400Hz sine wave and than a power amplifier module to transformer for the output but I think that that is too complicated for my application.
I have seen professional converters but they are far over my budget and look like killing a bug with a sledge hammer.
The manufacturers customer support of the water heater does not reply to my help request and only limits to tell me to contact the nearest technical support and that is in Germany and my water heater in Nicaragua so....not very helpfull.
(no thanks Vaillant!!).
Basically I asked them if there was not an option on the control board to make it work on 60Hz (There is a strapping on the board shown in the block diagram as S1 but it is not documented in the installation manual and I dont want to blow a brandnew heater) but no more answering after my querry on the strapping.
My cuestion obviously is....anny bright ideas how to build a converter???
Thanks,
Jos.
Thanks,
Jos.
