I'm looking to build my own cresting jig, this is a device used in the making of arrows for archery and simply spins the arrow around, a bit like a lathe, so you can paint the arrow.
As arrows are very light the motor doesn't need to be very powerful and really you only need one capable of around 150-200rpm. A lot of people who build these use a sewing machine motor but I'm reading a lot of conflicting advice on how to control the speed of it.
The motor I'm currently looking at is a AC Sewing Machine motor:
Rated power: 180 (W)
Rated voltage: 220 (V) AC 50HZ
Rated speed: 5000 (rpm)
Rated current: 0.9 (A)
This one or very much like it http://www.ebay.co.uk/itm/220V-180W...671175?hash=item4402bc4d87:g:K8YAAOSwR29ZCE4O
This comes with a footpedal to control the motor but I'd rather not use a foot pedal and instead want some kind of rotary pot so that I can set it to a particular speed and then leave it.
My initial thought was to just use a lighting dimmer switch as these are rated to 400W but I've read conflicting information with some saying that this is exactly how the foot pedal works and so perfectly safe and others saying that I'd actually need a fan dimmer switch. Others still say that you should use a dedicated motor speed controller saying that adjusting the voltage will harm the motor and that you need to change the frequency to adjust the speed.
Does anyone know which is the correct/safe method to use?
