I have a need for a setup where I would like to turn 12v power on and off depending on the input of a sensor that is outputting different voltage depending on the measurement.
Could you guys recommend a very simple and cheap component that could achieve this? Maybe a very simple one, that can handle simple if/else cases? For example, if input voltage is > 5V then turn on power on the output.
Any input is appreciated.
