I'm interested in creating a central 'hub' that can power up and power down all electronics in a person's house. In specific, my focus is on high energy consuming electronics such as the television, PCs, and games consoles. When I say "power down" I mean put the device in a state where it would consume less energy - not necessarily that the device has to be switched off, but ideas of that nature are welcome too.
Is there a way of achieving such an effect via hardware/software means? Any existing stuff out there that can be leveraged to achieve this effect?
And probably the most important (and likely difficult) criteria... can this device/technology be created in a way that it's generic enough to easily be modified to interface with different devices. So it shouldn't be reliant on the make of devices, rather the type should be sufficient e.g. work with most new brands of tvs is good, work with only Samsung tvs from the year 2008 isn't good.
Ideas I have - (these are probably terrible compared to what some of you can come up with)
- Some kind of a secondary socket like contraption which the user plugs their switch into, and this contraption is plugged into the 'real' switch. Essentially this contraption toggles electricity between an on and off state based on user of the central hub. The benefit of this idea is it can work with all products that are switched into a socket. The downside is, I think you'd only be able to toggle between on and off rather than power normal and power down.
- Maybe all electronic devices have some kind of standard which means you are able to externally send a signal (infrared/bluetooth/etc) to ask them to enter a low powered state. Given my current low level of electricity knowledge I don't know how stupid this might sound, but hopefully not too much
Please share your thoughts!
