Hello,
I'm trying to fix an IPL laser machine (generic nobrand from China). The problem with the machine, is that the LCD touch screen has no image, it's totally black. Without the LCD touch screen, the machine and laser is unoperable.
So far, after pulling everything apart, I found a burnt LCD driver chip on the LCD screen, so I have purchased a new identical screen (received), which I have mounted and tried, and still nothing but blank screen.
So I'm on to the controller logic board, looking for errors. Can't see any burnt components nor busted capacitors, but what I've noticed, is the LM1117 3.3v voltage regulator with heatsink that gets very very hot (maybe 60-90c - just a guess) within 2 seconds of plugging the AC power in. The LED light which I suppose should light up (marked with 3.3v) when power is connected, does not light up either.
Any ideas where to look for errors, how to measure, suggestions? Would be fair to assume that the LCD screen is powered by the 3.3V, and the problem is around that area...?
Thanks! Sorry, I'm quite green when it comes to electronics, but I'm trying to learn as I go
