Z
Zul
Hello,
Currently I building a circuitry to have 8 I/O pins being demux into
64 mutually exclusive outputs to control switching of 64 selenoid
relays. I am planning to place a Darlington array in between the
output of the demux and the ground for the relay because I believe a
demux output can't sink high current enough to operate a relay.
My problem arises as both the demux and the darlington array are open
collector devices. In this case the output of the demux are either
ground or floating. For darlington array the input must be LO (output
to floating) or HI (output to 0.6V). As I see it, I could not get a HI
input from an output of a demux with open collector configuration.
I was thinking to place an inverter between the demux and the
darlington array. I also looked for a demux with totem pole
configuration with active HI to match it with the darlington array but
could not find it. All I can find are demux with active LO.
If anybody have the opinion this, appreciate the response.
thanks,
Zul
thanks,
Zul
