John Doe
On the plug, ground is the larger of the three metal pieces, is that
correct?
I would like to connect a monophonic audio signal to the line input of
my soundcard.
Is it OK to leave one of the two stereo contacts left/right open? Or
should the monophonic audio signal be connected directly to both?
The physical connection/soldering stuff is not a problem.
Thank you.
correct?
my soundcard.
Thank you.
