Anthony Cerrato
----- Original Message -----
Newsgroups: alt.electronics
Sent: Tuesday, April 06, 2004 1:20 AM
Subject: Re: Connecting Headphones to RCA OUTPUTS?
Yes, I saw that adaptor, but unfortunately, my input to the
WH is a miniPhono, I guess 1/8", but it is male--which is
what is throwing me for a while.
Thanx--I thought that would work but wasn't sure. Now I just
need the right adaptor(s) as you note below. Sometimes ya
just can't find stuff like that in the web site search--pays
to mosey down to Radio Shack and ask for it...which I'll do
ASAP.
Yes, thanx for clearing that up--it's been much too long
since I tried studying electronics.
Yep--this will be a great way to go... if'n I can only get
that
@##$%^&_!@ adaptor! At least I understand the options now
and what I'm doing. Thanx again Jeff and y'all here for your
help! ...tonyC
First, I from your post, I cannot tell if the input to the wireless
headphones is 1/8" male or 1/8" female. If it's 1/8" female, an adapter is
widely available.
It is sold as a 1/8" to RCA cable - often used (or
marketed) to connect a portable device (ie CD player, MP3 player) to a home
stereo system. The 1/8" connector is used to connect to the CD player and
the RCA to the amplifier. In your case, the 1/8" connector connects to the
input of the headphones and the RCA to the amplifier. When you go to the
store, just ask for a cable to connect your portable device to the
amplifier. (Cables are bi-directional, so 'sound' can 'flow' from A to B
and also from B to A).
ASAP.
If the input to the wireless headphones is male, you will have to do some
searching for approprate connectors. (None come to mind right now) It may
take a combination of a few different connectors.
The volume control of the headphones does not control the input
voltage/current. The controls on the headphones only change 'stuff' that's
in the headphones. Since the wires are not connected to the headphones,
this control doesn't affect the input signal. It does affect the volume
though, so you would use these to control the volume.You should be fine with
the voltage/current ratings however the headphones might have a low input
impedance which would load the VCR(was it?). But this shouldn't be too big
of a problem.
If you already own a pair of wireless headphones, use them as you don't have
to worry about being teathered to the equpment.
that
help! ...tonyC
