Dear Forum. Is it ok to connect different sizes of panels but same voltage(12volt and different wattages) facing different directions together in parallel? I have a 150 watts 12 volt panel (mono) mounted in front and 30 watts but 12 volt (not mono) panel at back of the house. Can I connect them together to increase the amperage? The cables are drawn in and can be joined together at the charge controller. I actually have two separate charge controllers. One is 40 amp while the other is 20 amp. I want to see if joining the two panels will bring up the amperage for my 200ah gel Battery's charging. We are in a very sunny location. Sun runs from morning till around 5 pm at this period. I use a 40a Sunmate Solar Controller.Thank you.
Platforms
Content
