Hey there,
I'm wondering what would be the best way to connect a battery (not a car battery, something smaller, maybe like a drone battery) to multiple consumers that work on different voltages (all within the range of 1.5-12 volts) .
I can probably make a few parallel connections to the terminal and then use a step up or down circuit for each connection, and then solder a proper connector for the matching consumer. I wonder if this setup would work and if there are better ways to do it. It doesn't have to be a DIY project so if there's a particular device that does some of this job it would be best.
