Jukka Aho
Hi!
Here's the problem:
DEVICE #1
.--||---||-----| 2.5 mm | "Tip" = 'open collector' type
< || || | stereo | data port (0...5V)
`--||---||-----| plug |
`-----. | "Ring" = DC output (5V)
T R S | |
`-+---+-' "Sleeve" = GND
DEVICE #2 | |
.-+---+-. "Tip" = 'open collector' type
| | data port #1 (0...5V)
.--||---||-----| 2.5 mm | "Ring" = 'open collector' type
< || || | stereo | data port #2 (0...5V)
`-------------´ "Sleeve" = GND
T R S
I intend to connect the devices together (for some remote
control / programming experiments.)
Coincidentally, the connectors and signals are almost identical
on both devices, but Device #2 has two 'open collector' type
data ports (on "tip" and "ring") whereas Device #1 only has
one (on "tip"), and designates the "ring" connection as
a +5V DC output instead.
The second data port is not needed for this application;
I would just like to safely disregard it.
Now, what I'd like to know is what would happen if I dared
to connect these devices together using a simple, directly
connected cable like the above? To recap, both ends have a
common ground, but one has an 'open collector' type data port
(0...5V) on the "ring" whereas the other end would connect
a 5V DC supply there. This "ring" data port is not needed
for anything, but would I fry it or short something with
this kind of connection?
The devices in question are a LANC camcorder and a TI
programmable/hackable calculator. The intended application
is to use the calculator as a wired remote control device
for the camcorder.
Of course I could simply disconnect the "ring" wire to be
on the safe side. However, I would much rather use the
standard pre-made cable that came with the calculator if
it is at all possible (since this way others could too
easily use the same program without having to build a
special cable for themselves.)
I would appreciate any ideas and insights. Electronics is
not really one of my strong points, and I have a bit hard
time figuring out how the circuit would behave in this case.
znark
Here's the problem:
DEVICE #1
T R S | |
DEVICE #2 | |
T R S
for the camcorder.
znark
