Al Moodie
Not sure if this is the correct forum, but it is the only one I am
familiar with.
I have an old audio system, Technics SU 8022 stereo amp attached to
large quaulity technics speakers, works fine.
Have a Sony Bravia LCD TV which has an audio output socket which I use
for headphones occasionally.
Does it make sense to attempt to connect the TV's audio output to the
Technics amp to get better sound quality.
Sony TV Audio out:
500mVrms (100% modulation)
More than 1 Vrms at max volume setting
Impedance 47k ohms
Technics amp input:
Phono 2.5mV 47k ohm
Aux 150mV 27k ohm
I assume I will need some kind of voltage/impedance matching between
the two units.
Al Moodie.
familiar with.
Sony TV Audio out:
Impedance 47k ohms
Technics amp input:
Phono 2.5mV 47k ohm
Aux 150mV 27k ohm
the two units.
Al Moodie.
