Sir Procto . . . . . . .
Pray tell us . . . . WHAT transmitter do you have that operates, using an INEFFICIENT 12VDC voltage level at that FIERCE of an amperage ?
Both of your drawings seem the same, only with your improvement and learning curve being enhanced on the seconds better layout and its color coding.
Re:
I could only see the use of isolation / steering diodes on each supplys power output lines.
That separates the supplys from each other and that odd 20 amp supply could add in its output . . . . . isolated.
Each one doesn't care about the other . . . .they all just have to respond to supply, when that demand is made.
Should you opt for the diodes below a set of four 15 amp units would distribute the current loading between them.
The voltage spec is about the highest available in a Schottky diode and the lower doltage drop across each one of them.
It is also gonna conserve the most of that initial 13.8V, in the resultant voltage drop across them on EACH power supply leg..
Unless they happen to be adjustable, so that you could set the voltage output up just enough to make up for the diode voltage drop.
You can pay an arm and a leg for some metal cased units and even the TO-220 and TO-3 cased units are pricey.
Check out something like this:
http://www.ebay.com/itm/20-PCS-15A-...R-RECTIFIER-for-solar-panel-DIY-/271961586414
Thassssit . . . . .
73's de Edd
