Computer PSU to make a hot wire cutter ?
F
Frank
I want to make a hot wire cutter to cut forms out of polystyrene or
styrafoam. Can I cut off the molex plug from the end of one of the power
leads of a PSU & use a black wire/ground and either the orange/3.3v or
red/5V wire ? I have an old 250Watt unit lying about that I thought I could
use. If anyone has done this please give me a few tips
thanks
mike
thanks
I'd use the 5V winding cause everything else is probably regulated
from that.
I would put a LOT of thought into the vent hood you will use to catch
all the fumes so you don't get dead. Make SURE you know EXACTLY what
you're cutting and the toxicity of the fumes produced.
mike
Return address is VALID.
Bunch of stuff For Sale and Wanted at the link below.
Toshiba & Compaq LiIon Batteries, Test Equipment
Yaesu FTV901R Transverter, 30pS pulser
Tektronix Concept Books, spot welding head...
http://www.geocities.com/SiliconValley/Monitor/4710/
F
Frank
I have a old (no longer used) cell phone charger & power supply that
converts AC (120V) to DC(8.4V). Cuting the connector off the end exposes a
red & a black wire. Maybe I can rig this up - any idea how to figure what
guage & length of wire to use ?
James Sweet
What's the current rating? THe charger is probably not enough. Try using the
5v output of a PC power supply as someone else suggested.
