Hi. I may be moving to Australia from the UK and wondered whether it
would make sense to bring my PC, monitor etc or buy new. I know the
voltage is the same but wondered if there might be other problems. The
plugs I understand are a different shape too but would I just be able
to replace a UK 3 pin with an Australian 3 pin?
Thanks for any advice.
Electrically there is no problem at all, just change the plug to an
Australian one. (or replace the IEC cord with a local one).
Power here is 240vac 50hz. It should be noted that Australian
household sockets are 10a maximum (not 13a like there). If you have
any appliances that draw ABOVE 10a (like big heaters, clothes dryers,
welders etc) you will need to have a 15a socket installed by an
electrician - this will have its own dedicated circuit and circuit
breaker at the power-box.
Things like plugpacks or such (where you can't replace the plug) you
should consider bringing UK power boards and put local plugs onto
them. (This will probably be cheaper option for you with stuff like
your computer gear where using the powerboard, will only need
replacing one plug instead of several items that you always use
together like computer gear, stereo components etc)
The one computer problem you might have here is modem compatibility,
if you have dial-up or ADSL, modems, they possibly might not work over
here on our phone system, even if you change the telephone plug. Check
first, or maybe someone else on this group might be able to advise
you.
The TV system here is different, so I wouldn't bring a TV or VCR.
Video tapes you bring will play here though without problems on local
equipment.
Some overseas cordless phones are illegal to bring here (due to them
using frequencies that arent licensed for cordless phone use here)
