Component values are unknown
I have a circuit consisting of ESP8266,STM and a single relay.
For supplying power to these IC I need an SMPS circuit.
I got a non-isolated buck converter (using VIPER06Xs) as shown but the component values are unknown.
Could you please tell the suitable component values needed for this circuit? I chose this converter because the PCB that I will be planning is small in size.
Voltage needed for ic--
  • ESP = 3.3 V
  • STM = 3.3 V
  • RELAY = 5 V
https://www.st.com/resource/en/datasheet/viper06.pdf
The circuit posted has its ground connected directly to mains electricity so it presents a serious shock hazard and this thread should be closed with the warning.
Considering that the SMPS module is non-isolated you are completely right.
@wounder : I suggest you use an isolated SMPS for safety reasons. The green area then is safe under this condition. You should not trade safety for size!
I think you need to supply a bit more info about the project as a whole.
You need to know the current drawn by the relay (5 V is insufficient information). The use this our resource for selecting componnet values.
Could you please provide other SMPS circuit rated(min of output 500mA)
davenn
In post #3, how is this circuit connected to ground?. It looks completely fine to me. Am I missing something?.
Martin
agreed
huh ??
and how did you determine that the off the shelf charger he is using is non-isolated ?
Yes, his first cct showed a non-isolated converter … BAD
but the cct in post #3 doesn't and as long as @wounder uses a smps as in post #3 he will be good to go
I'm about ready to clean up this thread stating with AG's screwball post
I think AG and Harald have both missed something
But I await some responses first
The Viper 06 Buck Converter shown in post #1 has its ground connected directly to one side of the electricity with no isolation.
