Hi Folks!
Not sure if I'm in the right place on the Internet but....I want to make a PCB and am hoping to get some very basic help with this.
The nice thing about this project is that it has several easy 'success points' built into it. Even if I only succeed on the first one, which should be the easiest, then it's all been worthwhile. If I have success with anything after that, it's a bonus! Each successive step is incrementally more involved although, I am sure from your perspective they would all be easy.
The first step should be pretty simple. I want to interface an existing daughter board with 35 pins into the custom circuit board and have it output into an OE-style connector with 33 pins. So really, all I'm doing is taking lines from the 35 pin daughter board and routing them to the proper location on the OE-style connector. Even if I only succeed with that simple step then this has been worth it!
The picture I have in my head is my custom main board, with a 35 pin female connector on it, and 35 (or so) straight lines going to the proper locations on the OE-style connector. In short, 35 (or so) copper traces from the 35 pin connector down to the 33 pin OE-style connector.
Along the way I need to install a simple fuse on the power feed line to protect the daughter board. That's step one. In my mind, this should be really, really simple.
I have some electrical experience. Not much, but I can solder and my needs in this project, even assuming I can get all my optional features installed are not much. I'm certain for you folks they would all be a no-brainer!
I could either make the actual PCB myself in a one-off scenario or have someone make it/them for me.
Anyway, I researched PCB design software briefly and it seems Eagle is the way to go. The thought I had was that I would get a nice screen where I could, for arguments sake, drag 'n drop a 35 pin connector on a board and then create lines going to drilled holes where the OE-style 33 pin connector would go. This doesn't seem to be the case or I'm not doing something right
The reason I'm posting this is to see if anyone is interested in helping me with just the very basics of this thing. I've got an inexpensive hot air re-working station coming (because I needed a soldering iron to replace the $5 finger burner that takes 15 minutes to heat up) and I've printed off a wall sized chart of any schematics that I'm going to need. I am determined to do this thing and as I said, even if I only get as far as making a custom board that the daughter board can connect to and outputs to the proper pins on the OE-style connector, then it's a success.
Any ideas on more/less graphical software that I can use to get started? Or am I taking the wrong approach? I'm kind of guessing that a schematic is not really necessary at this point?
