What voltage do all these compact fluorescent "lamps" use ..?
And what waveform/frequency is required (used) ..?
They run off standard 50/60Hz A.C. line voltage/current e.g. 120V or
220-2440V. The internal electronics sorts out what's required.
What did you *really* want to know ?
I want to know what is applied to the *tube*, because I want to possible use
the ballast for other purposes. Like 48V dc -> 12V dc, after all they seem to
have all the stuff for a dc/dc converter.
Eeyore said:An LCD backlight is essentially the same thing AIUI. You'll find plenty of info
on drivers for them. IR have some dedicated CFL drivers too.
Graham
His ridiculously long username, his sloth, and posting to s.e.dJonathan said:please try spending a little of _your_ time searching
_and_ informing us first about the scope and limitations
of what you found, next time.
You may have done some searches already,
but you said nothing about that.
Jonathan Kirwan said:On 30 Sep 2006 08:29:07 GMT,
[email protected] wrote:
Have you tried googling about it or using Wiki? My recollection is
that the compact fluorescents operate in the 20kHz area and operate at
a low power factor, but I did what you should have done, I think. I
went to wiki and google and quickly identified this page:
That probably provides as much detail as you may need.
But please try spending a little of _your_ time searching _and_
informing us first about the scope and limitations of what you found,
next time. You may have done some searches already, but you said
nothing about that.
LCD drivers have some nice big transformers on their pcb. However they are
harder than CFL ballasts to come by, and are more cumbersome to handle. As
there usually is a whole laptop included![]()
nothing about that.
I figured if I know the voltage on the tube I can approximate the
transformer ratio in the ballast.
I need the transformer for an PoE project. But I also figured CFL ballasts can
be used for cheap dc/dc (48->12V) converters. Another source for cheap dc/dc
can be those mobile phone chargers. But I suspect they have too high ratio on
input/output (230->4V) voltage. And they are harder to get by in large amounts.
Well, I had no way of knowing any of that. It would help a lot to
know what you didn't find useful and where you had looked, already.
It's better to write more, than less -- up to a point. You respect
the time of others, that way.
You haven't mentioned whether or not the article I pointed out was any
use. It's quite possible it isn't.
I don't imagine a "voltage," here. There is a necessary cold starting
voltage and perhaps some other steps early on, but once ionized, isn't
it the case that current control is the important issue?
I remember from doing a flash lamp many years ago (30) that the
voltage supply is something like 300V or thereabouts. My guess is
that compact fluorescents with tube lengths somewhere in the
neighborhood of a similar length will need roughly similar voltages,
with starting voltages much higher (I had to use about 4kV to trigger
the lamp, memory serving, supplied by a trigger transformer driven off
of the 300V on its primary winding.) What's actually required to
start these lamps, I don't know.
If my memory serves on another score, to avoid depositing needed gas
atoms on the tube surfaces, it's important to use AC and, if possible,
fairly high frequency AC is better than low frequency (up to a point,
which seems to be about in the area of the 10-30kHz.) The better
frequency to keep the atoms from depositing is a matter for physicists
to discuss, but I think that frequency is a typical area.
So these do NOT seem appropriate for dc to dc converters. The parts
may be useful, such as the current limiting inductor, for example. But
the design topology seems all wrong to use in its entirety.
I don't know what a "PoE project" is, but I do know what a 48V to 12V
dc/dc converter is, generally anyway. Since you are into adaptations
of one kind or another, why not just design and build one and scavage
parts from where you can?
Nope. There was a model that used an incadescent lamp as a ballast for a 4
foor fluorecent lamp. Ran off 230 VAC - no igniter IIRC.
If they ran off about 50 or 60 VAC I wouldn't be surprised.
Hmm. I just went over to that PDF file I'd mentioned and they seem to
talk about 300V there. So perhaps I'm not far off base.
Well, I'm almost dead certain that compact fluorescent (at least,
those in the US) run at high frequency. The long ceiling tubes _do_
run off of 50-60Hz, as you say. But not the compacts, as I understand
it.
your sure about that ?
