We are using the ESP32-C3-MINI-1 chip as a wi-fi transceiver.
ESP32-C3-MINI-1 Transceiever datasheet:
https://www.espressif.com/sites/default/files/documentation/esp32-c3-mini-1_datasheet_en.pdf
Forgetting for a moment that about the RF side of thsi chip, ..the chip receives/transmits data by copper tracks into its pins 30 and 31 respectively.
These signals go to a connector which accomodates a cable which goes off board. We are concerned about this cable acting as an antenna and creating a radiated emissions problem.
As such, we wish to put a common mode choke(s)/ferrite bead in these traces, right by the connector. Can you recomend any ferrite beads or common mode chokes for this? I presume since there are three lines (RX,TX and GND), that really a common mode choke is not practical, and that a ferrite bead in each line would be best?
