Hi all,
I started working on the circuit for my lab bench power supply . I am using a 12-0-12 v center tap transformer for this. I took 24v from the transformer ,rectified it and used it to power external loads . Then I used the 12v part to power the cooling fan.I thought of including my arduino (to add some current sensing features ) on the 12v side and so gave a common ground between the upper and lower bridge rectifiers. On powering it the capacitor on the 12v side blew up as the voltage across it was 24v. How did that common ground increase the voltage on the 12v side to 24v? Should I in the first place consider them as two individually powered circuits for me to provide them a reference point ?
Plz explain.
I have also attached the circuit diagram.
Thanks in advance .
Plz explain.
Thanks in advance .
