common ground to different dc out put voltages
banu
Hi all.
My circuit board needs two supply voltages (5v and 15v ) from
external power supply .I used two switching regulators ,one of which
gives 5v o/p with 4amps and other one 15v o/p with 3amps.i have taken
these voltages as input to the different ic's.i want to know that
shall i connect the two grounds of the different supply voltages as
common to the ground in my circuit board.please clear me ,because i am
not getting the required output voltage.
Thanks in advance.
With Regards,
bhanuprakash.
default
Hi all.
Thanks in advance.
With Regards,
bhanuprakash.
There should be no reason that two independent power supplies can't
coexist with the same ground - unless power is being sourced from one
and sicked by the other. Powering IC's on a board with the ground
reference to the digital and/or analog circuits should present no
problem.
Connecting both PS to the same ground on the circuit board is the way
it is done . . .
You can't take two power supplies with 5 and 15 and expect them to
power an audio amplifier that wants to see Plus and Minus 10 volt
supply rails to ground - that would smoke your speakers (at least).
What are you really trying to do?
banu
problem.
it is done . . .
Dear Sir,
Let me explain you the problem i am facing ,this may
take a few minutes to read out ,but please give me a solution to
this.my application board is in the devicenet network,Actually my
circuit board requires 3.3v ,for that i have taken 24v dc from the
devicenet(source of ps) and i used a regulator(which gives o/p
3.3v@300ma with wide input range 4.7v-25vdc) that converts 24v dc to
3.3v and gives an output current of 300ma.In my circuit board i have
differntiated the ground from the devinet(source of ps) to analog and
digital.when i am measuring the output voltage using an DMM(digital
multimeter),with DMM +ve terminal placing at output of ic and -ve
terminal at the ic ground(which is digital ground).i am getting
1.2v.When placing the DMM -ve terminal at the devinet(source of ps)
-ve,i am getting a 2v ,what could be the problem.Why i am getting
differenet voltages by movingthe DMM -ve terminal to two
locations.Please give me your possible solution to fix the error.
banu
problem.
it is done . . .
Dear Sir,
Regards,
banuprakash
