Let's put in the part you snipped just to remind the group that
you're a liar:
Yes I sure remember when I
untangled you saying that the gain between 2 amplifier stages was
equal to the sum of the gains of each individual stage! Do you need
the url on that?
F*cking liar. You didn't discuss that with *me*. I knew that over 20
yrs ago - if you're talking gain in dB, anyway.
You didn't even try to worm your way out of that.
Ummm I'm not not satisfied with your answers.
Uhmm... ask me if I care. But if the OP's still around, maybe he'll
benefit.
I prefer the 3rd answer - less hand waving. The first 2 answers are
better suited for someone just learning the basics.
maybe you can't explain
yourself . Why should you bypass something that is there?
Filter cap. Filters out ripple and supplies transient current that
might otherwise change the drop across the supply's Thevinin
resistance. Keeps the signal off the rail.
Why is the
impedance of the DC voltage source low?
Because if it were high, too much voltage would be dropped across
its Thevinin resistance, Rth, and it wouldn't make a very good
voltage source. The voltage at the source's terminals would be more
dependant on the load it's energizing.
In #2, I said it "looks like a short" Relative to RC which is in
series with it, it's a short. In #1, the filter cap is the AC short.
