AJ said:
ESR the caps in the vertical deflection circuit, may find numerous ones
due to age of the monitor. Change any that check out of tolerance and
change the vertical output device.
Thanks for your feedback guys. However it's been so long since I've
poked around inside a monitor / TV that I am uncertain where to look.
Is the vertical section you refer to, the LOPT etc ?
I was considering looking on ebay for another one of these but if I
could resurrect this one, I would save a few pennies. However it is
possible, this unit may be on its way out. The brightness is up full, to
get a normal picture. When using separate chroma and luma inputs from
the C64 computer, colours still "interfere" with each other eg brown
text on a blue background is almost unreadable.
Anyhow, the immediate problem is these lines on the top third of the screen.
I appreciate your help.
