since you havent listed any specific models I will have to guess at what you are thinking about.
as an example ...
I have both a communications analyser and a spectrum analyser.
the comms analyser is the trusty IFR1200 google it for pics and in depth info
basically its a AM and FM signal generator from ~ 10Hz to 1000MHz and - 130dBm to + 10dBm, it has a built in RF power meter up to 150W, has a freq counter to 1GHz (1000MHZ)
It also has CTCSS tone and audio functions amongst other helpful features and finally, yes, it has a spectrum analyser as well... BUT the Spec An section is relatively basic in its functions
my Spec An is a Tektronix 2715 which goes from ~ 10kHz to 2GHz and like most spec ans it doesnt have all the other features of a comms analyser, tone generator, signal generator, hi power power meter etc etc.
BUT my Tek Spec An blows the IFR spec an out of the water with its accuracy of power readings and other frequency measurements of sidebands, spurii etc etc
Most comms analysers are basically a "toolbox in a single package" .... if you are into say "land mobile" installations and servicing etc then one of these is essential
But if you want to do really good spectrum analysis then a dedicated spec an is also a requirement
on one of my www site pages is a pic of the spec an right at the bottom of the page....
http://www.sydneystormcity.com/test_gear.htm
note other pics need updated just havent had time
cheers
Dave
