I have 3.5mm audio outputs from two different devices. One is a TV and the other is amazon echo dot. I need to connect them to my sound system on the same 3.5mm input channel. Now from what I have read it is not safe to use audio splitters for this purpose as the output of the two devices might not have resistance protection.
So question is what is the best way to combine these two outputs? Is there not a simple to make the audio cable with a Y connection and possibly add some kind of resistance to prevent audio from one device going to the other device? A bit like the concept of a signalling diode?
I came across the following item on ebay: http://www.ebay.co.uk/itm/172859360361
Has anyone used anything similar? will this do the trick?
