Combine two line level audio signals?
Noozer
I want to combine the line output from to PC's into a single set of
speakers. I know that reversing a Y cable is probably a bad idea. What's
the simplest way to do this properly?
jasen
a couple of 1K resistors will be enough to protect your soundcard's outputs
from each other.
| This is an ascii schematic, if the diagram appears garbled |
| try switching to a fixed-pitch font (courier works well) |
| pasting it into notepad works well on ms-windows. |
| in google groups selecting 'fixed font' (top right of page) |
| or view source (options) work too. |
fixed channel combiner
.----- right left
Sterio jack plug | | | / |\ /|
_ _ ____ ___________| | | / | \/ |
/ ~-_/ ## | ## | | / | / |
\ _-------------------------------/ common | |
\_-~ \_##____##___________-----------------------------------
common 1 ---.
|-------------- common out
common 2 ---'
left 1 --[1K]--.
|----------- left out
left 2 --[1K]--'
right 1 --[1K]--.
|---------- right out
right 2 --[1K]--'
If you get hum from that something more elaborate is needed
I've not seen cables like this for sale anywhere so you'd have to make
them. the cheapest way to do a reasonable job is probably to solder
the resistors in-line and use heatshrink to insulate and strain-relieve
the joint
Noozer
.-----  right  left
common 1 ---.
common 2 ---'
left 1 --[1K]--.
left 2 --[1K]--'
right 1 --[1K]--.
right 2 --[1K]--'
Thanks! Thats the information I needed to know.
