Hi all, so im trying to fix a filter coffee machine which does not power on.
Well certain parts that are tied to mains directly llike the steamer and heater work.
the rest doesnt switch on.
the clock works but as soon as power button is pressed it tries to switch on, screen goes blank for a second then clock comes on again and repeat.
i removed the PSU, looks like no damage on it , i checked the resistors and they are good, replaced the cheap caps with brand new good name brand caps on the psu and front control panel but no change.
if i remove the relay then the device powers on like it should , except the water pump or whatever is connected to the relay doesnt work, same goes for if the transistor is removed, which i also replaced.
i measure about 7.9v at the relay coil when switched on with relay removed.
its like it loses power as soon as the power button is pressed and then switches back on.
im attaching pics of the psu and control unit.
