CNC Machine Help
I am having issues with a CNC machine (grbl arduino) I recently purchased. My machine does not raise from the zero position to the first cutting point, it drags along the board and messes up my work. Any idea why that happens?
This is what I am
attempting to achieve
This is how it looks in GRBL Controller Visualizer
result when engraved.
Would need the relevent G-code for that portion of the move.
If the top of your board is 0, then the tool requires a move in the minus to clear the board.
M.
This is the GCODE
( CopperCAM - 25/03/2016 / ISO-Mill Output )
( C:\COPPERCAM\CopperCAM.iso created 06/06/2016 at 21:06 )
( Workpiece dimensions: 35.563 x 30.323 x 1 mm )
G21 G40 G54
G80 G90 G94
T1 M06 ( Basic Engraver )
M03 S9000
M07
G00 X-4.291 Y16.566
G00 Z0
G01 F900 Z-0.25
G01 F600 Y6.225
G01 X-4.854 Y5.924
G01 X-5.441 Y5.441
G01 X-5.924 Y4.854
G01 X-6.225 Y4.291
G01 X-21.646
G01 X-21.861 Y4.694
G01 X-22.344 Y5.281
G01 X-22.931 Y5.764
G01 X-23.601 Y6.122
G01 X-23.812 Y6.186
G01 Y16.638
G01 X-23.249 Y16.939
G01 X-22.661 Y17.421
G01 X-22.179 Y18.009
G01 X-21.878 Y18.572
G01 X-6.137
G01 X-6.122 Y18.521
G01 X-5.764 Y17.851
G01 X-5.281 Y17.264
G01 X-4.694 Y16.781
G01 X-4.291 Y16.566
G00 Z2
G00 X-5.98 Y21.753
G00 Z0
G01 F900 Z-0.25
G01 F600 X-5.764 Y22.159
G01 X-5.281 Y22.746
G01 X-4.694 Y23.229
G01 X-4.024 Y23.587
G01 X-3.296 Y23.808
G01 X-2.54 Y23.882
G01 X-1.784 Y23.808
G01 X-1.056 Y23.587
G01 X-0.386 Y23.229
G01 X0.201 Y22.746
G01 X0.684 Y22.159
G01 X1.042 Y21.489
G01 X1.262 Y20.761
G01 X1.337 Y20.005
G01 X1.262 Y19.249
G01 X1.042 Y18.521
G01 X0.684 Y17.851
G01 X0.201 Y17.264
G01 X-0.386 Y16.781
G01 X-1.056 Y16.423
G01 X-1.109 Y16.407
G01 Y6.225
G01 X-0.546 Y5.924
G01 X0.041 Y5.441
G01 X0.524 Y4.854
G01 X0.882 Y4.184
G01 X1.102 Y3.456
G01 X1.177 Y2.7
G01 X1.102 Y1.944
G01 X0.882 Y1.216
G01 X0.524 Y0.546
G01 X0.041 Y-0.041
G01 X-0.546 Y-0.524
G01 X-1.216 Y-0.882
G01 X-1.944 Y-1.102
G01 X-2.7 Y-1.177
G01 X-3.456 Y-1.102
G01 X-4.184 Y-0.882
G01 X-4.854 Y-0.524
G01 X-5.441 Y-0.041
G01 X-5.924 Y0.546
G01 X-6.225 Y1.109
G01 X-21.487
G01 X-21.503 Y1.056
G01 X-21.861 Y0.386
G01 X-22.344 Y-0.201
G01 X-22.931 Y-0.684
G01 X-23.601 Y-1.042
G01 X-24.329 Y-1.262
G01 X-25.085 Y-1.337
G01 X-25.841 Y-1.262
G01 X-26.569 Y-1.042
G01 X-27.239 Y-0.684
G01 X-27.826 Y-0.201
G01 X-28.309 Y0.386
G01 X-28.667 Y1.056
G01 X-28.888 Y1.784
G01 X-28.962 Y2.54
G01 X-28.888 Y3.296
G01 X-28.667 Y4.024
G01 X-28.309 Y4.694
G01 X-27.826 Y5.281
G01 X-27.239 Y5.764
G01 X-26.994 Y5.895
G01 Y16.638
G01 X-27.556 Y16.939
G01 X-28.144 Y17.421
G01 X-28.626 Y18.009
G01 X-28.984 Y18.679
G01 X-29.205 Y19.406
G01 X-29.28 Y20.163
G01 X-29.205 Y20.919
G01 X-28.984 Y21.646
G01 X-28.626 Y22.316
G01 X-28.144 Y22.904
G01 X-27.556 Y23.386
G01 X-26.886 Y23.744
G01 X-26.159 Y23.965
G01 X-25.403 Y24.039
G01 X-24.646 Y23.965
G01 X-23.919 Y23.744
G01 X-23.249 Y23.386
G01 X-22.661 Y22.904
G01 X-22.179 Y22.316
G01 X-21.878 Y21.753
G01 X-5.98
G00 Z2
M09
M05
M02
How do you generate the GCode?
You need to update your post processor...
Look at the following:
G21 G40 G54 '''Options Set
G80 G90 G94 '''Options Set
T1 M06 ( Basic Engraver ) '''Set Spindle (Or Tool number)
M03 S9000 '''Set Spindle RPM
M07
G00 X-4.291 Y16.566 '''Move to First XY Coord.
G00 Z0 '''Move to Z0
G01 F900 Z-0.25 '''Begin First Cut
G01 F600 Y6.225
G01 X-4.854 Y5.924
G01 X-5.441 Y5.441
G01 X-5.98 '''Last Cut Move
G00 Z2 '''Move Away from bed
M09
M05
M02
GCode is easy to learn
G0 = Rapid Movements.
G1 = Feed Movements.
From the looks of things, the cutting height is adjusted with the 'Z' axis movement.
Can you please confirm operation of your CNC machine?
Does the Bit lower itself first... Then move before cutting?
Or does the bit simply just move to the first cut location without adjusting it's height? (Most likely)
From the looks of things, if the CNC bit is manually raised off the work piece *first* before you run the file, then it would not drag across the material like it has... But that's unreliable.
Adjust the post-processor or program you are using to automatically raise the cutting head before the first G00 move has been issued. This will save you a lot of future head-ache.
Please feel free to post your post-processor or screenshots of the settings and I can help you work through them.
M.
Minus move would result in a deeper gouge in the material... too far, and it would cut into the table (or bed).
I'm aware of different CNC setups, but assuming -Z movement is the solution without seeing example code is a little dangerous.
Correction, my mind was else where, the standard Cartesian coordinates is of course the Z moves UP in the +.
Also in my opinion the initial Z should be positioned First to a posn above the work before the XY move, the Z could be at any position at that point.
If unsure where the +Z is needed, do a dry run with no tool in the spindle and it should show up immediately.
M.
M.
Preferably before the spindle is turned on, but always before the first XY move.
I would personally try inserting 'G00 Z2' After the T1 M06 line, immediately before the spindle speed set line... but would honestly like to see it much sooner.
(It's not uncommon to return all of the CNC axis to a known location early on in the program. At least returning the Z axis to something known...)
Similar as when I set a mill or gantry machine up for individual as well as All-Axis option homing routine, I make sure the Z homes first and then XY together..
M.
M07
G01 F600 Y6.225
G01 X-4.854 Y5.924
G01 X-5.441 Y5.441
M09
M05
M02
Thank you very much. I am playing around with Z0 and getting good results. I will let you know if it works perfectly.
Caution here though... The first G00 Z0 line I highlighted occurs *after* the first XY movement...
These two lines are the first two movement lines in the Gcode you shared above.
If you simply modify that Z0 to something else, the machine may still drag the bit through the material or along the CNC bed.
It would be best to place an 'additional' line before this.
G00 == Rapid Movement. ( Can move one or more Axis at the same time by using X, Y, or Z followed by the *position/Distance for each Axis)
G00 Z2 ''' will Rapid Move the Z-Axis to 2mm high (or 2mm higher depending on operation mode)
Easiest would be to put this Immediately before the "First XY Coord." movement.
The rest of your code looks fine. The Code does move the cutting tool up by itself after a cut, and between cuts, so this should only be necessary before the very first move.
Typical CNC GCode programs start with a number of 'G' and 'M' codes . This is typically the 'setup block' of the file which is supposed to 'cancel' any previous modes, and 'set' the modes required for the file.
An example of this is 'G21' used at the very beginning. This sets the operation mode to 'mm' ... otherwise if you had previously operated in Inches, your program could end up wrong.
After these 'mode-set' commands, the machine is typically moved 'rapidly' to it's beginning position with the G00 command . Look for this!
If there is a G00 command that moves the X and|or Y direction *before* a G00 command that moves the Z direction, you may have a problem.
After this first move, the machine typically 'feeds' into the material with the G01 command. This command can and often will have all 3 axis (X, Y and Z) but may only have Z when operated on the Type of CNC you have.
GCode is simply a list of instructions and moves for the machine to make. Once you understand that G00 is 'rapid' and G01 is 'Feed' ... you should be able to read the file manually to determine if the machine makes any odd moves, or to determine what may have gone wrong.
G00 should *never* make a move that would touch the material or table... This is a 'rapid' move and is often much too fast for the bit... This can result in damage to the bit or machine.
Only the G01 command should issue a move that may touch the material.
Good day, I have been able to rectify the dragging issue by following your solution. However, I have another issue. When I generate a gcode, the spindle is expected to move to Z0 and then engrave 0.25mm into the board (Z-0.25) but my machine's Z axis ranges from 20 to -9.9 and 13.5 is where my spindle touches the PCB's surface. Is there a way that I could make Z13.725 my standard engraving position. I know I could manually change all Z-0.250 to 13.725 but that can be tiring if the code is very long. I am using a very cheap CNC machine.
You should be able to 'home' or 'zero out' your CNC machine.
There are couple different ways of doing this... from manually jogging the CNC bit down until it *just* touches the material and manually running "G92 Z0" . This will Over-ride and set the *current* CNC machine Z-Axis position to *read* and function as the new 0.
However... The 'G54' at the beginning of your program set's a "Local Work piece" offset which may 'undo' this manual set. Please take a look at your CNC *controller* and look for anything related to 'Offsets', or mentions of G52 to G59 .
*We are looking for a set of X, Y, and Z numbers that we can adjust to that the CNC machine *thinks* that the Z0 position is where you want it. This will greatly simplify things, as you can write all of your programs to reference the top of your material to 0, and cut at Z-0.250 without having to much around with the CNC files after it is made.
