PPP
Hola!
I am looking at Texas Instrument's CD74HC538 monostable multivibrator.
Going thru the datasheet, I noticed that it does not have anything for
Voh (high level output voltage for TTL loads) at VCC ranges lower than
4.5V.
Does that mean that I won't be able to drive a TTL switch if my voltage
supply range is around 3V?
I found an analog switch also on Texas Instruments that work at 3V, but
it is labeled as having a TTL input. I wanted to interface this with
multivibrator.
Any hints?
Gracias!
4.5V.
multivibrator.
Any hints?
Gracias!
