J. David
Using a CMOS 555 (TLC555) at 5V , I wonder if tying both reset pin and
trigger pin together leads to a stable configuration as a monostable. The
reset/trigger pins being normally low, I would like to trigger the 555 just
by pulling them high and get a one single pulse.
So the question: will the 555 go out of reset state then acknowledge the
trigger because the trigger pin will also be low at that very moment? There
is a slight difference in levels between reset (around 1V) and trigger
(1.5V). But the rise time of the driving pulse being quite fast (in
nanoseconds), I can't figure out if the the internal circuitry will react
always the same way or unpredictably.
John
John
