I am building a DC-DC converter to power vacuum tubes with the higher voltages they typically use, all from a 12V supply. This current project involves a small pentode amplifier (technically beam sheet tube, 6ME8) that will work with about 30-60 volts on the anode resistor. I'm using the MC34063 as shown in the uploaded schematics.
The tube is breadboarded itself, along with the converter I designed onto a PCB, and another that I have on the breadboard, such that either can be alternately connected to the tube. The PCB board can operate from 50 to 200 volts, while the breadboarded version is designed for 30 volts, and doesn't have an external transistor, but more filter capacitance.
Regardless of design, no matter the amount of filter capacitance, the grounding offered by a ground plane on a PCB, both circuits produce the same clicking noise of about 1 to 3 hz or so. I'm not sure if I need to switch to a true PWM design, such as the UC3843. Any tips or suggestions appreciated.
