Norm Dresner said:
Is there any method(ology) for selecting an incandescent bulb that will work
in this circuit or is it just a matter of using what someone else has found
works?
TIA
Norm
Pretty much any bulb, can with a lot of buggering about be squeezed into
doing this. Main problem using opamps etc, is that the lowish, cold/hot
filament resistance change has to padded out to with extra resistance while
still allowing the feedback resistors to just straddle the <3.000X thru
If there's not much signal power available, then feedback resistors of say
2k and 1k would give a ideal gain of 3.000X. Having measured the bulb it may
be be 20ohm cold to 50ohm hot. That 1k resistor now needs reducing to (say)
970ohms and the bulb plonking in series. This gives a circuit hot/cold gain
change from 2.960X to 3.02X. Oscillation (3X) is when the bulb is 'warm' at
(critically) 30ohms. The bulb is a small difference playing amongst big
numbers and the feedback resistors need to be precise, or more usually the
oscillation point is found by tweeking a preset pot.
My GenRad bridge osc' thermistor failed. Eventually got the damned thing
working using 3X 12V 50ma bulbs in series. 5 bulbs=barely any thermal time
constant, so the osc' squegged. Two or less and not enough power and too
just too small an R to usefully use.
(Nowadays I'll use an LDR/LED combo. just uW needed to control kohms of
linear resistance change.)
regards
john
