I remember reading somewhere that the main point of a circuit is having a good signal to noise ratio. hence S:N
So when I am hooking up my guitar pots, I am thinking "too much noise" and trying to clean the fender out of the gibson. Anyway, As I remember the term S:N is counter productive in the fact that a good S:N is important eg. a high signal, S:N would be delivering a ratio that is stronger in signal than it is in noise; and a low signal, S:N would be delivering more noise than signal.
In fact, there is really no identification of good S:N because some applications require more noise.
So you build "whatever" with the proper S:N for the device to work right.
In transducer data transfer, this is extremely important(guitar pickups are transducers) because the wrong S:N kills the signal.
I need to clarify this somehow, Where most commercial guitar electronics include a grounding that taps into all the fine controls bodys, the bridge, and then finally to the output jack, the noise I get is really crackly and sometimes buzzing so loud that I can't here the transducers over the hum. I chose to bias the input and output, with the controls, as junctions. That way, I don't have a noisy pot case in the signal... result is a better S:N. but it is still quite noisy on some settings, others are crystal clear.
I don't think there is a filter that can clean it up. I think I just have to find a way to not include the parts that are noisy(cheapo guitar electronics...not my bag, gotta find a fix)
