Clamp Meter -- No Contact on Dual/Three Wire AC Current Measurement????
NYC Doc
Can clamp meters determine AC current on conventional extensions cords that
have two conductors and a ground?
thanks in advance
JeffM
that have two conductors and a ground?
NYC Doc
No. Only 1 conductor can be in the clamp.
mike
thanks in advance
Simplest thing is to unplug the cord and insert a current tap and
clamp the probe around that.
There is some technology using field measurements for power lines.
I've seen an article on a handheld instrument that can measure
the current in zip cord. Claimed 10% accuracy. Does some kind of field
measruement that can
distinguish between the different distances of the wire from the sensor.
Not sure if the third ground wire messes that up. Twist probably
doesn't help either.
The meter was so far out of my price range that it seems that I didn't
save the reference to the article.
mike
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Wanted 12" LCD for Compaq Armada 7770MT.
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
Don Taylor
Sure, carefully split a few inches of the cord so that you don't expose
bare copper but do separate each of the two conductors and ground
and clamp the meter around one of the non-ground conductors.
