circuitry to delay a square wave clock signal
PhilCBR
Hi guys,
I am new here and am hoping someone can hep me with my 800Hz cloc
problem.
I need to time delay a 800Hz square wave signal by 0.3ms. What sort o
simple circuitry can I use to time delay my square wave clock signa
by this short amount of time?
Thanks,
Phi
Andrew Holme
PhilCBR said:
Hi guys,
I am new here and am hoping someone can hep me with my 800Hz clock
problem.
I need to time delay a 800Hz square wave signal by 0.3ms. What sort of
simple circuitry can I use to time delay my square wave clock signal
Thanks,
Phil
You could use an RC low-pass filter followed by schmitt trigger, or, the /Q
output of a monostable (for a delayed rising clock edge). It depends how
accurate the delay needs to be.
If you want accuracy, and can live with up to 100nsec of jitter
(+/-50nsec), get yourself a good cyrstal-controlled 10HMz oscillator,
and and use it to clock your square wave through two D-type bistables.
Use an exclusive-OR to compare the outputs of the two D-types, and
whenever there's a difference, turn off the clock to the second D-type
for 3,000 ticks of the 10MHz clock (for which you will need a 12-bit
counter - in the past I would have used a pair of 74HCT40103 binary
down counters).
http://www.standardics.philips.com/products/hc/pdf/74hct40103.pdf
These days I'd find a programmable logic device with a least 14 latches
(which is pretty small).
Jim Thompson
I have a two-edge delay circuit around here somewhere. I'll post it
to a.b.s.e when I find it.
...Jim Thompson
Jim Thompson
...Jim Thompson
See...
Newsgroups: alt.binaries.schematics.electronic
Subject: Two Edge Delay (from S.E.D) - TwoEdgeDelay.pdf
Message-ID: <[email protected]>
...Jim Thompson
