I am making a automatic water dispenser (schematics attached) using DC motor, solenoid and IR sensor module (https://robokits.co.in/sensors/ir-a...MIjbWz7Krm6QIVVwQrCh1H9gv2EAQYAyABEgJoCPD_BwE).
Submersible Dc Motor pump: 3-6V DC 100-220mA. Driven by 2NAAAA2 transistor.
Solenoid Valve water: 12V DC(rated 0.6Amps). Driven by TIP120 transistor.
5V IR sensor module connected to input pin of arduino.
The system is powered by 12v DC adapter.
Now, I want to make sure that the noise from the motor or solenoid doesn't affect the other components in the circuit. What other components (resistors, capacitors, etc) should I add at different points of the circuit to avoid noise ? Is some sort of RC filter needed to be added to the IR sensor output pin going to the arduino input ?
Also, I am planning to use a bigger 24V DC motor pump (rated 2Amps) in place of existing DC motor pump for another project. What precautions to be taken in this case to avoid noise?
Or is a two channel relay board (probably the ones with optocouplers) a better option without transistors?
And I am planning to add a 250V 2Amp glass fuse for overcurrent protection along with a diode (IN4007) for reverse polarity protection between the power supply adapter and the LM7805 IC.
![upload_2020-6-4_7-18-25.png upload_2020-6-4_7-18-25.png](https://makerv2.webteractive.co/forums/data/attachments/46/46920-21d21e385a40777ea07dd9ca84abc959.jpg)
